LS 3 Engine Specs
LS3 Engine specs
Balanced: Internal Block Part Number: 12584727 Bore x stroke (in): 4.06 x 3.62 (103.25 x 92mm) Camshaft duration (@.050 in): 204 degree intake / 211 degree exhaust Camshaft Part Number: 12603844 Camshaft Type: Hydraulic roller Compression ratio: 10.7:1 Connecting rods (P/N 12617570): Powdered metal Crankshaft (P/N 12597569): Nodular iron Cylinder heads (P/N 12598594): LS3 rectangle port; as cast with 68cc chambers Displacement (cu in): 376 cu in (6.2L) Engine type: LS Series Gen IV small-block V-8 Maximum recommended rpm: 6600 Pistons Part Number: 19165089 Pistons Type: Hypereutectic aluminum Recommended fuel: 92 octane Reluctor wheel: 58X Rocker arm ratio: 1.7:1 Rocker arms exhaust Part Number: 10214664 Rocker arms exhaust Type: Investment cast, roller trunnion Rocker arms intake Part Number: 12569167 Rocker arms intake Type: Investment cast, roller trunnion Valve Lift (in): .551 intake / .522 exhaust Valve size (in): 2.16 intake / 1.59 exhaust |
