STILLEN's AP Racing Big Brake for 2010 Camaro
STILLEN is now offering an AP Racing 6 Piston Caliper/16” Rotor Big Brake Upgrade for the 2010 Camaro that is available with matching 4 piston rear calipers with 15” rotors The 2010 Camaro big brake upgrade kit by STILLEN is part of the company's Brake Pros product division. Check out the release below: The carefully matched front and rear kit includes an AP Racing 6 piston front caliper with oversized 16” 2-piece floating vented rotor and 4 piston rear caliper with 15” 2-piece vented rotor. The kit is engineered to stop the 2010 Camaro on a dime – street or track. Manufactured for maximum stopping power and minimum brake fade, the kit offers high performance braking capability with race proven technology and comes complete with calipers, rotors, brake pads, coated stainless steel braided brake lines and all necessary mounting hardware for immediate bolt-on. Strong, durable and designed to withstand any punishment, AP Racing Brake calipers are manufactured with a stiff, lightweight, pressure cast aluminum alloy 2-piece body and finished with a hard anodized 2-part paint finish, optional in black or red. Differential piston bores eliminate pad taper and maximize braking efficiency, and the anti-rattle clip eliminates pad knock and noise. A fixed radial mount ensures minimal caliper flex for the best available brake feel under all operating conditions. Two-piece modular rotors float on an aluminum hat and have directionally curved vanes to maximize cooling in extreme brake situations. Both front and rear rotors are available in a cross-drilled and slotted pattern for an aggressive pad bite and better face cooling, or can be purchased slotted only. Ferodo brake pad compound, DS2500, is standard and is uniquely formulated for high load and extreme heat up to 1100° F. To learn more about AP Racing Big Brake upgrade kits for the 2010 Camaro and other high performance vehicles, visit www.stillen.com, e-mail for more information at pr@stillen.com , or call STILLEN’s knowledgeable tech staff at (888) 221-2892. |
STILLEN's AP Racing Brake kit for 2010 Camaro photo
