Camaro with air suspension?
Modern standards in automotive style are slightly different. The tire profile tends to be smaller as long as the ground clearance which makes a car look flushed to the ground.
Of course it looks nice, but in fact lowered sport suspension cuts wings of your car and you can forget about former ride comfort. Every time you drive out, you have to think about the speed bumps and how many people you can take aboard, which turns driving into a nightmare if you run extreme setups. Air lift suspension is a good option if you want to achieve that stylish look of a lowered suspension and still keep normal ride height and comfort when it's needed. Here's a couple of good examples of daily driven cars, and for sure there's a lot of fancy showcars that you have seen on the internet:) http://www.carid.com/images/for-foru...aro-lift-5.jpg http://www.carid.com/images/for-foru...aro-lift-4.jpg http://www.carid.com/images/for-foru...aro-lift-3.jpg http://www.carid.com/images/for-forums/camaro-lift.jpg Few years back the installation of an air suspension was something that not many shops could deal with, but today it's absolutely not a problem to order an airlift conversion system and get it it installed locally. What we offer is a complete set of Air Lift suspension for a Camaro, that includes all required parts and hardware: Air Lift® - Performance Air Suspension Kits http://www.carid.com/images/air-lift...tems/98001.jpg Option1: 4.2" x 4.2" Digital Combo Lowring Kit - Best Performance Air Suspension Digital Combo Lowring Kit with 4.2" Front and Rear Body Drop by Air Lift®. With 30-Way Adjustable Threaded Body Front and Rear Dampers. Without Front Sway Bar End Links. With Front Leader Hoses. Modifications not Required. This is an electronically-controlled air suspension system for front strut/rear shock vehicles with stand-alone air bags that replace original coils. Provides over 4 inches of ride height drop when aggressive performance and looks are desired. Features individual adjustment of all 4 springs, automatic rise on start, 8 memory settings, and side-to-side roll. Wiring, air lines, and hardware are also included. Option2: 4.2" x 4.2" Manual Combo Lowring Kit - Good Performance Air Suspension Manual Combo Lowring Kit with 4.2" Front and Rear Body Drop by Air Lift®. With 30-Way Adjustable Threaded Body Front and Rear Dampers. Without Front Sway Bar End Links. With Front Leader Hoses. Modifications not Required. This is a manually-controlled air suspension system for front strut/rear shock vehicles with stand-alone air bags that replace OEM coils. Analog controls mount in the vehicle, and feature paddle style push buttons to raise and lower spring pressure manually. Wiring, air lines, and hardware are also included. + It's the right time to purchase it now and save $ for the installation. http://www.carid.com/images/air-lift...omo-banner.jpg And the big question: Coilovers or air suspension? |
| All times are GMT -5. The time now is 06:52 AM. |
