Temperature control issues
I have a 2014 2ss and i just wanted to see if anyone could help me out the ac doesn’t and the heater doesn’t work either. The temperature control does absolutely nothing and it used to work fine my a/c is charged and my coolant was recently changed so it has to do with the actual ***** everything else does work like the intensity of the air that comes out but the temperature doesn’t. basically what ever the temperature is outside that temperature i get and *** the engine gets hotter so does the air. Even if i close the outside air circulation anything helps at this point i want to get it fixed before summer thank you I appreciate it
Spartan66
Dec 31, 2008 12:24 AM
