Center console gauges
I have the same question. From what I have seen on youtube it is possible. I can buy the gauge pod from gmpartsdirect but need to figure out if it is plug and play or do I need to add the trans temp sender and oil temo sender to the pod. Anyway if I figure it out I will post again although I suspect after all this time you may have already figured this out.
it's super easy for 2012 and newer cars, all you have to do is buy the correct gauge cluster and put it in, all the wiring and sensors are already installed.. so the install takes about 5 minutes and no tools needed. I did it myself.... just take care to order the correct cluster.
