speed limiter - how to disable
I hit my speed limiter for the first time on my new 1lt, 118 mph, what is the easiest/ cheapest way to get it set higher? can a dealership do this when I get the right tires?
thanks |
Reprogram the computer to delete the speed limiter.
yeah...how do you do that?
I'm thinking you probably have T rated tires, which is why the limiter is there.
Before gettin' all speed happy, keep safety at least somewhat in mind and make sure you're running tires that'll handle the speed you're after. |
Originally Posted by AboveTheLogic
(Post 644566)
Before gettin' all speed happy, keep safety at least somewhat in mind and make sure you're running tires that'll handle the speed you're after. does anyone know how to do reprogram the speed limiter or not? |
You need to buy a programmer, generally run $300-$400 iirc. Then learn to use it.
Or, bring it to a dyno shop or get a mail order tune. dont think its worth it to just remove a speed limiter. Mod the car, tune it and do it then if you still want to |
Originally Posted by Rombama
(Post 644614)
i didnt ask for a safety lecture,
(Post 644614)
does anyone know how to do reprogram the speed limiter or not? Just don't go running over your tire speed rating, lose control, and kill some innocent bystanders in the process, please. If you're not keeping safety in mind, I'm not going to help you and I'd hope that nobody else does either. |
(Post 644716)
Too many careless kids on these camaro forums I've noticed, sheesh :icon_iamwithstupid:
Obviously...
| All times are GMT -5. The time now is 04:29 AM. |
