OEM Mini Fuse Block Spare Fuse Empty, need terminal
In the trunk of the 2010 Camaro on the right side is a mini fuse block has about 6 or so spare fuse spot, but in order to utilize these spots to blend in with OEM wiring I need a female terminal crimp thiny to crimp to my wire and plug into the rear of the fuse block, then I can insert the mini fuse into. Does anyone know what the proper name for the female terminal is and where to buy online instead of going to a salvage yard for a GM mini fuse block?
