Camaro virgin...need help
Hi fellow camaroforum's:
I just bought a 2010 ss, which was the #1 model built by 'Innovative Retrokits' in WI. Fabulous car. Am struggling to resolve a 'check engine' light issue. The car was fitted with B&B s/s exhaust, l/t headers and hi-flow cats.
The cats seem to be the cause of the problem. Does the obc need to be re-calibrated to recognise the new cats?
Any suggestions would be welcome.
i went ahead and moved your thread to the 5th gen section. go ahead and do a intro in the introductions section where i moved this thread from and tell us a little about yourself, where your at and more about the car with some pictures. i use photobucket and it seems to work very good. all ya gota do is open new account, download pictures and copy the img code to your post. the picture shows.
Hi CM:
Thanks for the response. I did contact the builders and they assured me that the car passed all emmission tests after the conversion. The local chevy dealer has never dealt with this type of conversion before and has no idea where to start with the diagnostics. At $200 per hour, I am not about to give them the green light on an investigation that could take up to 2 days. The car performs perfectly. Gas consumption is good, oil pressure good, all the temps are normal.
I would just like to get to the bottom of the problem.
torque_is_good
07-02-2010 09:20 PM
