Trans., Pinion/Carrier gears weak/under-spec''d components?
Login | |
Trans., Pinion/Carrier gears weak/under-spec''d compone... - 8/19/2008 7:02:27 PM
libertyforall1776
In my ''01 SS w/just under 89k mi., I just had my 2nd rebuilt-trans installed last week (manifested in delayed gear shifts and higher RPMs than normal for a gear) and 2nd pinion seal leak (resulting in low-diff fluid) both were re-done about 12k mi. ago... This time I had to have the pinion bearings carrier bearings replaced, as they were damaged (loud whirring noise from rear-end). Is this not uncommon for this car/configuration when you drive it hard? One would think the trans would be stronger... Also had the alternator replaced due to headlight/dash flicker, and low-note horn had died. Extended Warranties sure are worth it.
_____________________________
01 Camaro SS Convertible: SLP FlowPac & Dual-Dual exhaust, G-Stop SS Brake Lines 02 Camaro RS Coupe: SLP CAI & Dual Exhaust 95 Camaro Coupe 3.4L: SLP CAI, Flo-Pro muffler
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
