how much $$ to convert a 3.4 to a LT1??
Login | |
how much $$ to convert a 3.4 to a LT1?? - 8/19/2008 6:05:32 AM
tylerparson
i have a1995 3.4 automatic. i am considering converting the old girl to a LT1 6-speed car. is it worth the conversion?? how much money and work am i looking at?? is there anything i need to be aware of before i go any further??
RE: how much $$ to convert a 3.4 to a LT1?? - 8/19/2008 1:25:18 PM
Guest
You dont need a new rear end or new tranny. The 4L60E was used in both v6 cars and v8 cars, the bellhousing will be a bit different, and I think you''ll need a new torque converter, but seeing how you stated you wanted it to be a 6 speed Im guessing you already know you need a new tranny. Guys, honestly I think we need to be a little nicer to people wanting to swap. Ive seen alot of wrecked z-28s and trans ams in my area and an LT1 with a full wiring harness can be had for about 750$. Its a more viable option to some, and it certain instances can be cheaper if you can find a wrecked donor car. Im just sayin....
RE: how much $$ to convert a 3.4 to a LT1?? - 8/19/2008 1:48:49 PM
tylerparson
so if i wanted to leave it as an automatic, i could just use my stock trans??
RE: how much $$ to convert a 3.4 to a LT1?? - 8/19/2008 4:18:11 PM
Guest
If youre going to talk about paying a mechanic to do the swap your in over your head already. Have you ever seen a salvage yard? You guys make it seem like this stuff is worth its wieght in gold, where ever your getting your prices from those are incredibly high. I dunno maybe its just me but you guys always quote prices higher than anything Ive ever seen, I mean 200 for a guage cluster? Are you buying new? Where do you get this stuff? That, and 3-500 for a limited slip rear end with disc brakes? You REALLY need to be checking your information dude......
< Message edited by 6v49der -- 8/19/2008 4:21:48 PM >
RE: how much $$ to convert a 3.4 to a LT1?? - 8/19/2008 4:35:50 PM
tylerparson
but it is a job that someone could do at home, with a good tool set and a cherry picker, right?? i have also heard that the wiring is the hardest part of it all to swap, it there any truth to that?? and can i use my auto. trans??
