Air Cleaner??
Login | |
RE: Air Cleaner?? - 8/18/2008 8:27:58 PM
Camaro 69
Sure can. Here''s what I did with mine: http://www.camaroforums.com/m_210489/tm.htm
_____________________________
Eats Rice and Poops Out Fords 393 Stroker, Tunnel Ram/Dual Quads, and a well used rear-view mirror
RE: Air Cleaner?? - 8/19/2008 7:15:33 PM
xeet2050
Hey thanks so much. Im about to get a new air cleaner. Will it help with getting anymore power or is it more for looks. My uncle said if i get a 14 in. it should gain a little power. But anyways thanks again.
RE: Air Cleaner?? - 8/19/2008 8:20:33 PM
Camaro 69
I did it for both looks and performance. It feels a little more responsive, not to mention the better sound from under the hood. And looking at the restrictive air flow path of the stock cleaner, it can only help.
RE: Air Cleaner?? - 8/19/2008 8:23:47 PM
Camaro 69
Oops, it double-posted
< Message edited by Camaro 69 -- 8/20/2008 7:07:05 PM >
RE: Air Cleaner?? - 8/19/2008 9:35:59 PM
MadMikeZ28
quote:
ORIGINAL: Camaro 69 I did it for both looks and performance. It feels a little more responsive, not to mention the better sound from under the hood. And looking at the restrictive airflow path of the stock cleaner, it can only help. Thats why when I have a stock cleaner I grind the spot welds and pull that ring out of the cleaner. While the cleaner is off put the lid on and squeeze it down like when its bolted on and there is not much space in there with that ring in place.
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: Air Cleaner?? - 8/20/2008 5:34:15 PM
xeet2050
So when i take off the spacer ring will i have to remove any tack welds or anything?
