Restyle your Camaro with Remin Main Dash Kit at CARiD!
Custom dash kit is an ultimate do-it-yourself accessory, which is designed to refresh or personalize your vehicle's interior in minutes. Nobody can customize your Chevy Camaro 2016-2017 better than you and our Remin dash kits will help you do upgrade your interior with your choice of Carbon fiber, Aluminum or other modern materials that are not available in stock. The new kit is available for Camaro models with 7'' and 8'' touch screen.
No other dash kit brand gives you a better choice of finishes like Remin. Real wood, aluminum, carbon fiber or any other solid colors – everything to make your Camaro look like your dream-ride. Each and every piece is CAD designed and laser cut for a perfect fit. They feature the clear polyurethane coating, that does not yellow and ensures permanent good looks, protecting the decor surface from harmful UV rays. The trim pieces are mounted with 3M automotive grade adhesive backing for secure permanent attachment.
Remin® - Main Dash Kit
You can select one of 42 (!) finishes including Real Carbon fiber, Real and synthetic wood, Brushed Aluminum, Chrome and solid colors like yellow, blue etc.
Read more about Remin on CARiD: https://www.carid.com/remin/
Spice up the interior of your Chevy Camaro with Remin Main Dash Kit at CARiD!
carid
Vendor Special Buys
06-02-2016 06:40 AM
carid
Vendor Special Buys
04-22-2016 02:39 AM
carid
Vendor Special Buys
01-14-2015 03:54 AM
CFI
11-18-2011 05:56 PM
