Auto trans shift knob removal/wiring diagram
Old Jul 12, 2005 | 06:50 AM
sewerrat's Avatar
Default Auto trans shift **** removal/wiring diagram
Hello, I just got a 94 Camaro and I'm in the process of removing the miles of aftermarket wiring that the previous owner had installed. I need to lift the center console off to get to some wires that he ran under it, but I can't figure out how to remove the automatic trans shift ****? I don't see any allen screw or bolt near the ****. How do you remove it???
Second question is where can I find a really good electrical schematics on the 94 camaro? Mainly fuel inj, VAT, body harness, ect.. I bought a Haynes manual but I does not show enough detail. I'm trying to avoid going to the dealer.
Thanks for any responses.
Old Jul 12, 2005 | 07:05 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Auto trans shift **** removal/wiring diagram
doesnt the shift **** have a lil plastic piece holding it in? probably cant see it until the shifter is all the way back towards the drivers seat
Old Jul 12, 2005 | 07:13 AM
sewerrat's Avatar
The only thing I can see is a small cut running horizontally about 1/2" long on the front side of the shift ****. I probed it with a small screw driver but could not find any type of screw or bolt?
Old Jul 13, 2005 | 03:53 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
no it just pulls out with some needle nose pliers
Old Jul 13, 2005 | 05:46 AM
sewerrat's Avatar
thanks nj85z28 for the reply. I finally figured it out. The little slit is for a horse shoe shaped retaining clip which is missing, (kind of what you said). Once the clip is out the **** pulls straight up. Mine was really stuck! Thanks again, now I can clean all that dried soft drink stuff the previous owner left behind.
P.s. can anyone suggest on where to get a really good wiring diagram without going to the dealer??
HappySalesman
Jul 9, 2014 08:30 AM
camaroteen82
Apr 10, 2014 10:59 PM
Randy Bilyea
Jul 2, 2013 05:49 PM
fronzizzle
Aug 2, 2011 12:44 PM
LetsRockZ28
May 25, 2010 05:54 PM
