dry or wet shot
Old Oct 24, 2006 | 06:29 AM
vollybllplyr4's Avatar
Default dry or wet shot
can someone tell me about the difference between a dry shot and a wet shot? which is better for what? i have a 89 iroc, would it be better for a dry or wet shot? thanks
Old Oct 24, 2006 | 06:49 AM
94CamaroSFI's Avatar
Default RE: dry or wet shot
you will want to go with a wet shot. The "wet' shot is typically preferred since the nitrous is injected with additional fuel into the engine whereas a "dry" shot injects nitrous alone. wet systems can be tuned by adjusting the fuel pressure up or down. Dry systems rely on the engine's computer alone which for example if it senses it is running too lean it will pump more fuel but most factory computers were not designed with this in mind so they have difficulty compensating for the nitrous. The wet shot is injected directly into your intake (usually same place as injectors) whereas the Dry is shot through the air intake.
Old Oct 24, 2006 | 12:34 PM
shnormo's Avatar
How big of a shot do you want to go with. You can go with a 75 shot dry nitrous safely, but anything over that I'd go wet. You can get the easier wet shot that injects both fuel and nitrous throught the intake tube too. Direct port injection is a lot more expensive and you need to machine your intake manifold a little too.
Old Oct 24, 2006 | 03:18 PM
thanks for the advice. i was actually thinking about going with a 75 shot on my camaro
Old Jan 1, 2007 | 02:22 PM
CamaroKid16's Avatar
Me personally, unless your going for Really Big plans. The 75 shot on dry would be the cheapest and easiest bet for ya.
Chaotic94
12
Nov 4, 2010 06:58 PM
endo
Nov 18, 2009 09:34 PM
98ss4REAL
Dec 22, 2007 06:39 PM
javione
Feb 22, 2007 03:45 PM
chevycamarobadass555
Mar 6, 2005 12:04 PM
