Weird humming noise?
Old Aug 22, 2010 | 10:50 AM
19IroczCamaro87's Avatar
Default Weird humming noise?
I changed the timing on my car from 20 advanced (Bought it that way) to 16 since that was the lowest it went without dying. Since then a humming noise is made from start to finish and sounds like the fuel pump area. I was racing by friends cobra and then it starts studdering but not doesnt die. What can be the problem
Old Aug 22, 2010 | 02:52 PM
That is pretty severe spark advance numbers. You may want to review your timing procedure.
Old Aug 22, 2010 | 07:33 PM
microkid's Avatar
March 2011 ROTM
...and get a new pump. they will hum loud and cut out before totally dying and leave you stranded.
Old Aug 22, 2010 | 09:15 PM
The car doesnt want to drive at normal advancement
Old Aug 23, 2010 | 10:18 AM
Caveman305's Avatar
either your distributor is a tooth off or 180 out, or you forgot to unplug the wire on the pass side up by the blower motor when checking your timing
the car really should not be that far advanced if its in stock form,i see you have a GM crate thats a 355, factory spec on any thirdgen i have seen is 0 degrees BTDC,but even with the 355 and exhaust you should not be to 16 degrees, make sure you unplug that Brown(i believe) wire before checking your timing
jasunf
Jun 9, 2011 03:38 PM
Murda99v6
Sep 30, 2010 09:56 PM
Chevykicksbut
Sep 20, 2009 03:14 PM
davidalvarez82@hotma
Oct 28, 2006 03:28 PM
Sep 9, 2006 08:45 PM
