Subs
Old Jul 8, 2006 | 06:53 PM
02blackonblack's Avatar
Default Subs
I'm sure someone here's got a sub or two, my question is how in the world do you fit it in your trunk? lol. I just got my camaro and seeing as how the T-tops holder is in the trunk, I'm baffled as to where a sub would fit.
Old Jul 11, 2006 | 03:22 PM
user 7208220's Avatar
Banned
Default RE: Subs
you need to get a small box...for the trunk...or you can take your backseats out...which i did...yadabooboo?
Old Jul 21, 2006 | 09:12 PM
MadMikeZ28's Avatar
Default RE: Subs
check out crutchfield.
Old Jul 24, 2006 | 11:47 PM
Default RE: Subs
Update. I met some really cool guy at a parking lot where everyone races and checks eachother's cars out on the weekends and he custom made a box for two 12's and has it sitting at an angle so his tops still slide in. Takes some work but that's the best solution I've seen so far.
Old Jul 27, 2006 | 12:57 AM
Matt99camaro's Avatar
Default RE: Subs
If you don't mind putting the t-tops in the backseat then just remove the t-top holder. My box fits down in the hatch hole and up to the backseat. I'm runnning 2 15in subs in it. I had to remove the trim on the hatch because the subs were hitting it when they extended. I don't have people riding in the back of my car anyway so putting the t-tops in the backseat isn't that big of a deal, but it might be if you usually have more riders along. I can take a picture of my box tomarrow and post it if you want to see it.
Old Aug 1, 2006 | 03:12 AM
Corr182's Avatar
Default RE: Subs
I bought a sub box off ebay...... granted my t-tops lay over my amp and subs but it still shuts...
Old Aug 3, 2006 | 08:37 PM
dodgeram's Avatar
Default RE: Subs
hi i bought a 97 z28 from chicargo last year and it was fitted with small sub, 500watt amp, 50:1 cd changer all in trunk and i can still use t-top storage
[IMG]local://upfiles/921/B2970D1953D0476688D6F3E6CF19FE59.jpg[/IMG]
[IMG]local://upfiles/921/F9778DA35E3A41B78453B10305265617.jpg[/IMG]
[IMG]local://upfiles/921/0BAF3262C6A540AF82F331ECC0128F1A.jpg[/IMG]
cortes202
Jun 7, 2012 10:02 PM
greycon88
Aug 21, 2011 06:44 PM
Artful Driver
Nov 14, 2010 11:04 AM
BakerDL828
Apr 8, 2009 11:11 AM
red star
Dec 6, 2007 07:14 AM
