Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > Drivetrain Tech > General Tech
New! Use your Facebook to securely log into this site, click logo to login
Reply
Thread Tools Search this Thread
Old 03-10-2010, 09:27 AM
silamianos silamianos is offline
No cars in silamianos's garage, add now
Question i need some help with my 86 camaro
Hi my name is josh i just purchased a 1986 chevrolet camaro with a 2.8L multi-port injected engine with an automatic transmission. I've loved camaros since i was born and i kno alot about the history and little about fixing them. but the reason i need help when i purchased my camaro the guy got it to crank but said the battery was dead i have replaced the battery and it needed a new ignition switch which i also bought and installed everything is put together except for 1 red wired plug under the steering column i cant figure out where it goes if it goes anywhere and the car will turn on but will not crank or start for that matter any help is greatly appreciated....thanks
i forgot to mention that he got it to crank by doing something under the hood with a lug wrench. i believe he was manually cranking it i suppose but if im wrong please inform me and if somebody knows what im talking about can u please explain how to do it so i can get my car started thanks alot
This ad is not displayed to registered members.Register your free account today and become a member on CamaroForums!
Last edited by silamianos; 03-10-2010 at 10:40 AM. Reason: i forgot to mention details as to how the previous owner was starting the car
Old 03-16-2010, 09:50 AM
osduck5 osduck5 is offline
No cars in osduck5's garage, add now
If you have a volt meter, check the starter to see if you have voltage on the solenoid when the key is turned to the start position. You could have a bad starter solenoid. Not sure about that red wire. It being red, I would think it is a "hot" wire for something. MIght go pick up a repair manual at the parts store or used book store. They have the wiring diaghrams printed in there.
Old 03-20-2010, 12:02 PM
jriggseagle jriggseagle is offline
No cars in jriggseagle's garage, add now
a 86 camaro do you have a chip made into the key, i belive you should, that single wire is proably for you security , if that wire is not hooked up the car will not start, check a wiring diagram, make sure you have the correct ignitionkey\\\
Old 03-21-2010, 01:47 AM
HorizoN's Avatar
HorizoN HorizoN is offline
On The Tree
No cars in HorizoN's garage, add now
If I remember correctly, the security chip in the keys started in 89. I don't think his car has one.
Reply
Tags
1986, 86, automatic, battery, camaro, drain, ignition, iroc, starting, street, strip, switch, transmission, turning, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Camaro Parts
- Camaro Exhaust
- Camaro Car Cover
- Cargo Liner
- Car Vacuums
- Flowmaster Exhaust
- Leather Seat Covers
New Sponsors
Contact Us - Camaro Forums - Chevy Camaro Enthusiast Forum - Archive -
Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
