whats the diff.
Old Jun 21, 2006 | 12:36 PM
noahb270's Avatar
Default whats the diff.
what exactly is the diff. in an ls1 and an lt1 engine...thank you
Old Jun 21, 2006 | 01:25 PM
Default RE: whats the diff.
LT1/LT4
Based on original small block Chevy. For Camaro use is has cast iron block, aluminium heads, reverse cooling system, shaft driven water pump, distributor mounted on timing chain cover, camshaft driven oil pump, 2 bolt main bearing caps, sequential FI, short runner intake manifold.
LS1
Entirely new design. Aluminium heads & block, standard cooling, georotor oil pump driven directly by crankshaft, evenly spaced intake and exhaust ports, no distributor, coil on plug ignition, 6 bolt cross bolted main bearing caps, sequentila FI, composite material intake manifold.
There are very few parts interchangeable between engines. In genera,l the LS1 produces more power due to better head design.
mid535
Apr 14, 2011 09:48 AM
kdm212
Jun 2, 2009 11:25 PM
jeb
Mar 5, 2009 03:51 PM
bonedeth631
Jan 15, 2008 05:14 PM
