Fuel injection to carbureted
Old Mar 16, 2005 | 01:09 PM
SmithD's Avatar
Default Fuel injection to carbureted
I have and 85 camaro with a fule injected v6 in it. I have an camaro 305 iroc carbureted engine that i want to put in the car. How difficult is it to go from fuel injection to carbureted???
Old Mar 20, 2005 | 01:01 PM
Patrick's Avatar
Administrator
Default RE: Fuel injection to carbureted
the biggest issue that you may run into is the ignition...with EFI...everything works together, .i.e the fuel system, spark, so on..
however...going TO a carburated system should be easier...i would suggest going to an aftermarket ignition system such as MSD...
Old Mar 22, 2005 | 09:26 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
you have to change the fuel pump, otherwise the high pressure FI pump will destroy your carb. then, just turn around and sell the pump orginally in the car, alot of ppl do the opposite of what your doing and require a higher pressure pump
Old Mar 30, 2005 | 09:56 AM
DarkBirdZ28's Avatar
you not only have to chenge that fuel pump but the lines as well. you'll have to change the suspension and the transmission. I think you'll have to change the rear end and drive shaft too. the best thing is to find a donnor car that has the stuff you need.
Old Mar 31, 2005 | 07:21 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
i agree. just a get a wrecked IROC or Z28 and swap, swap, swap! everything that is different must be changed
Old Jan 25, 2006 | 06:12 PM
D83ZAdams's Avatar
why do u have to change the trans and rearend? On my 83 crossfire all i had to do was run a fuel pressure regulator, i used the stock fuel pump and just turned the pressure down. As for the ignintion I ran a indepent msd system. But it may be diff on a 85 idk?
Old Jan 25, 2006 | 07:16 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
because hes swapping from a V-6 to a V-8.
Old Jan 26, 2006 | 10:26 AM
McNasty's Avatar
dont really have to change the suspension in it... but once he starts riding in it he will want to... itll handle like crap with that v8 in it unless he changed it
Old Jan 29, 2006 | 12:11 PM
v8chvyguy's Avatar
Most of the suspention parts are the same the only difference is the springs, front brakes, and maybe the master cyl. The trans needs to be swaped that 85 probably has a 200 metric BOP tranny in it.
Burleyboy
67-69 V8 Tech
May 8, 2013 09:24 AM
electricheart4
Feb 27, 2008 05:53 PM
70_boosted
Jul 7, 2007 10:46 PM
86 camaro
Jun 1, 2007 03:58 AM
1983camaro
Oct 25, 2006 02:58 PM
