Stall speed on stock torque converter??
Old Nov 19, 2009 | 06:30 PM
ScottD's Avatar
Default Stall speed on stock torque converter??
Whats the stall speed on a stock torque converter for an 82? Im thinking about buying another (higher) one but dont wanna spent the time and money if its only a few hundred rpm difference...........
Old Nov 19, 2009 | 06:58 PM
microkid's Avatar
March 2011 ROTM
roughly 1800. what trans do you have, the 700r4 or the 2004r? there is quite a difference jumping from 1800 to a 2200-2400 stall.
Old Nov 20, 2009 | 06:21 AM
blackz87's Avatar
Stall speed for stock 700R4 is about 1600/1650 RPM's....
Old Nov 20, 2009 | 09:13 AM
ScottD's Avatar
OK, I guess I should have thrown this out there.....ive got a 3 speed TH350 (no overdrive). -Dont ask....the previous owner stuffed it in there.
Stall speed still the same??
Old Nov 20, 2009 | 12:59 PM
Jr. Mechanic's Avatar
August 2009 ROTM
There's absolutely no way to tell, unless you inspect the TC for markings.
Old Nov 20, 2009 | 02:29 PM
1990CamaroRS's Avatar
Fancy Sparkle
easiest way to find out, go out and test it. put it in gear, and slowly rev it up with the brakes on. when the rear tires finally break loose, that's right where your stall speed is.
Old Nov 20, 2009 | 02:41 PM
August 2009 ROTM
Yes, you can do a stall test, however it won't be accurate.
Old Nov 20, 2009 | 05:36 PM
Fancy Sparkle
it will give you a general idea at least.
Old Nov 20, 2009 | 07:23 PM
microkid's Avatar
March 2011 ROTM
that is an ase approved method for checking stall speed and is 90% accurate (if the trans isnt slipping). also, the more torque an engine produces, generally the stall speed will be higher
Old Nov 20, 2009 | 07:42 PM
ScottD's Avatar
Funny, because even with all the mods Ive done, sometimes when I do a 'brake stand' she wont spin the tires......just sits there and groans.....
