transmission may be shot
Old Nov 17, 2009 | 10:05 PM
endo's Avatar
Default transmission may be shot
well i was driving along in 5th, i down shifted to 4th and it felt strange so down shifted into 3rd and it got stuck there.
i was told that maybe it was a synchro that busted loose and got jammed in there. so i am going to take my consul apart so i can take a better look at the trany.
but i want to start looking for a new transmission too. the trany has to come out if i rebuild the one i have or if replace it so im thinking of replacing it.
so finally to my question what is the stock 5 speed manual trany from a 84 camaro v8 and is there any other transmissions that will bolt into place without modifying other things. or was the same transmission used in other cars.
also will a stock transmission work with a 350 that i may swap in later.
Old Nov 17, 2009 | 10:17 PM
mtn_maro's Avatar
stock 5 speed is the t-5.
Old Nov 17, 2009 | 10:27 PM
endo's Avatar
should i look into replacing anything else?
Old Nov 17, 2009 | 10:45 PM
mtn_maro's Avatar
depends on how crazy you are going to go with your camaro.
Old Nov 18, 2009 | 06:59 PM
endo's Avatar
is there a tranny that will bolt up to a 305 and a 350 that will handle the power from a built 350
Old Nov 18, 2009 | 09:34 PM
mtn_maro's Avatar
yes. if you are going manual trans then the t-56 from an lt1 camaro would be a good choice. but it takes some modification. if you are going automatic then a rebuilt 700r4 would do good. maybe get some strengthening done to be sure it wont blow out the bottom. but it shouldnt
imalixZ28
May 30, 2010 07:28 AM
mxskater56
Mar 30, 2008 10:41 PM
javione
Feb 22, 2007 03:45 PM
vollybllplyr4
Jan 1, 2007 02:22 PM
chevycamarobadass555
Mar 6, 2005 12:04 PM
