car stopped on highway
Old Nov 17, 2009 | 08:33 PM
thetal1's Avatar
Default car stopped on highway
my 95 3.4 just cut out on the highway. the rps's revved up but i went nowhere.
I figured i was out of gas
So i pulled over i had less than a quarter tank of gas. (1/8 probably)
The weird thing is that the needle has gone lower than it was at today.
So after container trying to start it and it just kept turning over i went to a gas station near by.
i got 1 gallon of gas and put it in the tank.
I tried to start it again then i backfired and kept turning over
So my friend brought me a 5 gallon tank of gas and after pouring it all in it just kept turning over again.
So i noticed after a while my battery was low so i tried jumping it and nothing happened.
then after getting it towed i came down to the fact that my car needs a new fuel pump.
If you can offer help on what else i can do other than dropping the rear end and taking out the tank or any other solution please let me know.
Im in plugging my battery now to see if reseting the comp helps.
(sorry for the long post i was just making sure i put everything in there)
Old Nov 17, 2009 | 08:59 PM
mbar's Avatar
can you hear your fuel pump kick on when you turn the key?
Old Nov 17, 2009 | 09:23 PM
02StanGT's Avatar
Auto or manual?
Old Nov 17, 2009 | 11:15 PM
libertyforall1776's Avatar
Sounds like you burned out the fuel pump -- run it too low, and the pump overheats -- happened to me in my '95 3.4L. Extended Warranties are your friend, by the way...
Check this out for another option -- a fuel pump door:
http://www.taekwondoplus.org/z28/fuelpump.html
http://www.worldisround.com/articles/12533/index.html
Last edited by libertyforall1776; Nov 17, 2009 at 11:21 PM. Reason: Added fuel pump articles
Old Nov 18, 2009 | 12:43 AM
evilkal's Avatar
If it's an automatic, I vote torque converter has blown.
Old Nov 18, 2009 | 12:26 PM
Shylock's Avatar
Last year I was driving had the cruise set. All of a sudden without warning everything went out. Volts dropped to 0. Fuel went to E, everything went. Would not turn over. Next day about $1,200 and a new fuel pump later. Open the gas door and put your ear to it. Have a friend get in and turn the key to see if you hear the fuel pump clicking. Good luck.
Old Nov 18, 2009 | 01:47 PM
thetal1's Avatar
its a manual.
the only thing i can hear is the click whe you turn the key right before you start it.
im gonna wait till someone comes over to try listening to it cuz my mom is just goin crazy from all the stuff thats goin on.
Old Nov 18, 2009 | 01:53 PM
thetal1's Avatar
ok if my mom ends up letting ME fix my car (it might sound funny but i cant afford any thing)
then i am pretty sure ill go and cut that hole
Old Nov 18, 2009 | 07:50 PM
Southpaw40's Avatar
Hey thetal, try this trick, Have your mom in the car and try and start it while you hit the gas tank with a rubber mallet sometimes you can jar the pump and see if it starts. if it does start replace the pump it will stop working again so do not trust it..
Old Nov 18, 2009 | 09:10 PM
thetal1's Avatar
just hit it anywhere?
