WHEEL SPACERS for Camaro rs 96
Old Nov 13, 2009 | 10:57 PM
camaro_florida's Avatar
Default WHEEL SPACERS for Camaro rs 96
hi
i want to put this
http://riggedup.ecrater.com/product.php?pid=892568
on my camaros rear wheels
my qustion is if i will have problems with the rear fenders in case of car is full loaded? if it could be that the tire will touch my fenders becuse the wheel will be sitck out from the fender
thanks
Old Nov 14, 2009 | 12:38 AM
Those spacers are 2" wide. So all you have to do is grab a tape measure and see if you have more than 2" of clearance between the front of your tires and the fender lip. If you do use spacer adapters, get the hub-centric type. Those ones you show rely on the lug nuts alone to keep the spacers perfectly centered on the axle hub, which means they could wind up giving you a wheel vibration.
Old Nov 16, 2009 | 11:09 AM
Masospaghetti's Avatar
^ I second that...also, you will need new wheel studs since your originals will be too short.
