t-top question
Old Nov 11, 2009 | 10:08 PM
doug91rs's Avatar
Default t-top question
im lookin to buy a new set of glass t-tops for my car but i have heard many different things about what sizes will fit my car. i have heard there r 2 different pin sizes from 82-92 what r these sizes n which size will fit my car? i have a 1991 rs. and if anybody is sellin a glass pair in great shape for less than 100 dollars let me know. thanks for the help guys
Old Nov 11, 2009 | 10:19 PM
You should have the large pin 7/8" diameter. Small pin is about 3/8". But the large pin t-top is actually dual fit, large and small. The outer large part is under spring tension and pushes in to expose the small pin. You could put on small pin tops if you find a smokin deal, but you'll have to change the pin receivers on the car to the small hole size.
Old Dec 11, 2009 | 04:58 PM
parmetta's Avatar
I recently purchased a set of glass t-tops to replace my worn out pexiglass tops. The proble i have is my new tops are locked. i was tols there were just 2 clips to pop off and I could replace the locks with my original locks. I haven't been able to locate these clips. The glass tops' locks are pop riveted in.
How do I replace these locks? if no easy way, how do I break the locks so I can use the tops?
Old Dec 11, 2009 | 05:19 PM
Drill out the rivets so you can remove that cover, and the rest should be obvious after that.
Old Dec 11, 2009 | 06:34 PM
350rs's Avatar
March 2008 ROTM
you put new rivits in to replace the ones you just drilled out?
Old Dec 11, 2009 | 06:50 PM
The rivets hold the cover on, it's there as a tamper resistant safety cover so the lock can't be easily removed by a thief. Once the cover is off, the lock can be removed. Reattaching the cover is optional.
Old Dec 12, 2009 | 05:48 PM
ScottD's Avatar
I have a set in decent shape. The only thing I know about fitment is they WONT fit my 82. If you want them, ill sell em to you for 50 bucks but you pay shipping. They are heavy and fragile. PM me if yer interested.
Old Dec 12, 2009 | 06:17 PM
parmetta's Avatar
Got the rivies out and my locks installed. Gonna keep the Lexan tops to ride out the winter (they do not leak) and keep these for spring. (leakage unknown)
Old Dec 12, 2009 | 09:58 PM
19jacks71's Avatar
man-oh-man i hate t-tops!!!nothing personel bro ....
your car is sweet but were im at ,,
the climate kills the seals and poof - leak-and-or-rattle city!!!
plus ive just always liked the smooth look of the streight hard top....good luck peace out....
Old Dec 12, 2009 | 11:31 PM
Good deal! The lexan tops have a metal frame around it, and are thicker than the glass tops. When I switched my tops over from the lexan to the glass, I had to lower the front and rear pin receivers to latch them down tighter. They were a real sloppy loose fit otherwise.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
