annoying/embarrasing idle issue
Old Nov 10, 2009 | 11:50 PM
1989_RALLYSPORT's Avatar
Default annoying/embarrasing idle issue
ok when i stop at a light sometimes my car surges from 550rpm to 900rpm an then down to around 300rpm then smooths back out to 55o rpm for like 30 seconds... the time between surges is totally random.
but if i hit tap the gas at the precise time it surges, when it drops back down it just dies.
it also stalls allot in reverse
oh btw i have a stock 305 tbi v8
its always done this even after a full tune up......
Old Nov 11, 2009 | 01:37 AM
Adam78's Avatar
i had a similar problem, but my camaro is carburated, 99% chance urs is fuel injected, and i have no idea how fuel injection works, but mine was a broken choke, i dont even know if urs has a choke lol.
Old Nov 11, 2009 | 04:05 AM
have u had it scanned for trouble codes?
Old Nov 11, 2009 | 12:25 PM
So full tune up...I presume plugs, wires, distributor cap & rotor, and checked the timing?
Is the air filter clean? You also might want to rebuild the TBI, it's not hard to do. If you've ever worked on a carb, you can do a TBI with one eye tied behind your back (or something like that)!
Old Nov 11, 2009 | 02:50 PM
no codes come up....
tune up makes no difference....
my car does run verry rich...to the point if you are standing by the exhaust your eyes burn..
throttle body has new fuel pressure regulator and injectors already
new fuel pump and filter too
even a new o2 sensor thinking it would lean out the fuel mixture some
nothing has helped
if i had the extra $ id swap to carbeurated
Old Nov 11, 2009 | 04:48 PM
Does it make a difference if it's a cold or hot engine?
Old Nov 12, 2009 | 08:31 PM
microkid's Avatar
March 2011 ROTM
remove and clean the idle air control valve. im not exactly sure where it is on the tbi unit itself, but it is a common issue that they get dirty. when they do, the stepper motor has a hard time finding the correct location, thus creating a hunting idle (aka surge). it could also be that the tps might be slightly out of range. there is a write up that will explain how to check it and adjust it. if you still have that problem, replace the iac assembly.
Old Nov 18, 2009 | 10:41 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
I am thinking IACV as well... or a tiny vacume leak... but codes...
Old Nov 20, 2009 | 06:27 AM
blackz87's Avatar
With the engine surging with RPM's going up and down, I would start checking for a vaccum leak.
Old Nov 20, 2009 | 06:14 PM
vacuum leak idk... ive been getting rid of lots of vacuum related crap.
the only vacuum stuff hooked up still is the brake booster. egr. climate control.
other than these 3 items i know of nothing else on my car still hooked up.
iac...is that the little sensor in my air cleaner?
and i dont notice the surging so much when it is cold but it is still there but hardly noticeable unless your watching the tach
