turning a 305 manually
Old Nov 2, 2009 | 12:22 PM
letsride212003's Avatar
Default turning a 305 manually
i have to turn the engine over manually and im unsure on how to do that i was told by the crank shaft nut which sounds right but i am unaware of how to do that if any of you know how to do it well and could provide me with directions on how to do that or provide me a link to a site that could help me out i would just bring the marro to a pro but it is stuck in my garage untill i can figure this out any help is greatly apperciated
thanks
1985 camaro 305 base coupe
Old Nov 2, 2009 | 04:56 PM
mtn_maro's Avatar
well assuming you are talking about just turning the innards most likely to bring it up to tdc then yes its just using a socket wrench on the end of the crankshaft nut. however if you are talking about trying to start the engine then i dont see you accomplishing that. there is no way you can manually turn it fast enough for it to start
Old Nov 2, 2009 | 05:19 PM
Y2K's Avatar
Y2K
....that hasn't been done for a long time lol.
Old Nov 2, 2009 | 05:56 PM
no not trying to start it, does it matter what way i go like are there things that i need to take into account before doing this
torque specs or anything like that
Old Nov 2, 2009 | 06:28 PM
ATM's Avatar
ATM
If you were to use an impact gun you may be able to start it. Never know til you try...
Old Nov 2, 2009 | 07:00 PM
microkid's Avatar
March 2011 ROTM
bar it over clockwise so that it is turning the correct direction, as well as "tightening" the bolt.
Old Nov 2, 2009 | 08:18 PM
mtn_maro's Avatar
hmmm i would think those engines would be a lot easier to manually than these engines....but i may be wrong! lmao. would be kind of an interesting story though.
yeah i was trying to bring my engine up to tdc and i put the breaker bar on and turned then all of a sudden it just fired up. breaker bar went right through my radiator =[ lol
Old Nov 2, 2009 | 08:27 PM
That's the way it used to happen back then, except it meant for some broken fingers or worse if the engine kicked back. And before any smartass says anything...NO I wasn't alive back then!
If you plan on doing a lot of hand turning, removing the spark plugs will make the job a lot easier.
Old Nov 2, 2009 | 09:14 PM
Y2K's Avatar
Y2K
He he,just shortly after 'eh.
I wasn't either but I used to have this old 1937 CAT 22 with a hand crank starter so I know how to start the old time stuff.
Old Nov 2, 2009 | 09:32 PM
bobarian91's Avatar
BackseatBob
^THAT thing is awesome!
