Engine Identification
Old Oct 11, 2009 | 05:35 PM
hardtail's Avatar
Default Engine Identification
How do you tell if an engine is a Chevy, Pontiac, Olds, ect.? All I see on the back of my block is "GM 5.0 LG."
Thanks.
Old Oct 11, 2009 | 06:08 PM
Forget the back of the block, and go to the boss on the left front (as you're facing the front) The code will tell you what cars it came in.
Old Oct 11, 2009 | 06:30 PM
The style of the valve cover is usually a dead giveaway.
Old Oct 11, 2009 | 09:00 PM
hardtail's Avatar
Here it is... the codes on the front left are 2DB271985 and KO517DDF...
Old Oct 12, 2009 | 12:54 AM
OK, we're not talking about a "brand specific" engine here, as in the older vintage engines. The "DDF" in the second set of numbers means it's a 1983 305, 145 h.p., LG4 (low output) engine. They were used in "F" body cars (Camaro, Firebird), "B" body cars (full size), and "G" body cars (midsize). It's a GM "corporate" engine, meaning the same engine was used across the GM line, not just Chevy. If the engine you have is going to require any extensive work to be usable, you would be better off using it in a boat....as an anchor!
Old Oct 12, 2009 | 06:45 AM
hardtail's Avatar
It runs now, just needs a starter. Picked it up for $100 so its good enough to learn on. I have no interest in building a race car. Later on I may upgrade to a 350 but for now it will do. I was just wanting to know what brand it was so I know what rebuild kit to buy.
Thanks.
Dreamcatcher
Oct 25, 2012 01:04 AM
mrsurfs
67-69 V8 Tech
25
Apr 16, 2012 06:35 PM
JumboNuttes
Apr 5, 2010 09:11 AM
cody69
Mar 13, 2009 12:24 AM
