Attention V6ers, important CAI info
DO NOT, I repeat, DO NOT buy your CAI off ebay like I used to preach. The tubes are too small, , the elbows are even smaller inside, and the filters are too short. They will cause a rich condition WOT in your car. Removing mine and running open TB was a difference in AF ratio from pegged rich, to about 15.0:1 without it (WOT). I suggest (for the first time ever) buying a name brand cold air intake, or making your own out of tubing that is as close to the same size as your TB inlet as possible. This is for early 3.8 guys, those without lids.
I've got 13's in my sight with this problem figured out.
I was thinking of using the parts for the ebay ones to build a duel inlet system. Just make the Y pipe myself. With all that extra air your car is gulping are you sure even a K&N one would be enough? Seems like a LT1 convertion might be in order for yours.
That's a good idea with the tubing, I'll try it out. I'm still stunned and the difference. It's pegged lean at part throttle cruising, so that setup was insanely restrictive.
There's some stuff that can be a good buy, just gotta be careful. It's like shopping at Fry's for computer parts, gotta know what you're doing (apparently I don't).
I've been working on a new setup to do on the cheap, I think I'm close to having something figured out.
And for those of us that have not ported and polished out heads to the max and running 350 HP @6K the ebay CAI is fine. I am getting around 32 MPG on the highway running 70-75 MPH.
Even a simple cammed engine will want to gulp more air, so if your engine is stock on the inside, shoot for ebay. Not stock on the inside, price your options for something that will flow.
This is what I'm planning. It's a bit overkill, but I figure, what the heck, why not.
2' of this (smooth on the inside, so I'm told):
http://www.zzperformance.com/grand_p...=319&catid=113
1 of these (cone filter):
http://www.zzperformance.com/grand_p...=246&catid=113
And I'll make a plate out of some aluminum I have at home, and have a buddy weld in a 4" pipe through the middle for me. The plate will screw over the hole to the inside of the bumper cover on the front driver side of the car, will make a seal to keep the engine heat out. Sorry for the ms paint picture (also note that the filter I might order is 9" long):
