350 Conversion
Old Oct 4, 2009 | 05:48 PM
ThirdGenCrazy's Avatar
Default 350 Conversion
We our racing season is over and we have a 350 Crate Motor that we can't use anymore. Just wondering how hard it would be to swap it in place of my Carbed 305 ( the 350 is carbed to ). I know if i swap it, the 700R4 can't handle 470HP. So on that note, how hard would it be to put a Turbo 350 trans. in it?
Thanks for the help.
ThirdGenCrazy
Old Oct 4, 2009 | 05:51 PM
zapperdan's Avatar
good luck
Old Oct 4, 2009 | 06:22 PM
350rs's Avatar
March 2008 ROTM
tons of kits for the tranny swap, i think you have to beat on the tunnel a bit though..
Old Oct 4, 2009 | 06:30 PM
could just building the 700R4 be another route to take?
Old Oct 4, 2009 | 07:44 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Yes, building the 700R4 is the best route to take. I had mine built for a little over $1200 and it's guaranteed up to 600 HP.
Billet input shaft, high volume oil pump, kevlar bands/clutches, Transgo shift kit, 2300 stall converter, and Corvette servos are just a few parts thrown into mine.
Old Oct 4, 2009 | 07:55 PM
and it should bolt up to the 350 correct?
Old Oct 4, 2009 | 07:56 PM
August 2009 ROTM
100%.
Old Oct 4, 2009 | 08:07 PM
microkid's Avatar
March 2011 ROTM
yea, the stock 700r4 can handle up to around 350 hp without any needed parts. after that, a shift kit will suffice in keeping the bands and clutches together as well as an additonal oil cooler. however, the 700r4 can handle just as much power as a t350, they are basicly the same thing with the exception of overdrive.
Old Oct 4, 2009 | 09:04 PM
well that's good. i've also heard that i need a bigger radiator for the 350. is this true?
Old Oct 4, 2009 | 10:23 PM
Lopez_SS's Avatar
You don't have to swap them but it is better to. I have a 350 I put in my camaro in place of the 305. Tranny 700R4 is holding up fine along with the radiator. You can tell a HUGE power gain
