Cruising rpm 3 speed
Old Sep 25, 2009 | 04:37 PM
Cblaze's Avatar
Default Cruising rpm 3 speed
Im thinkin about converting my six cylinder to a 350 crate engine with 260 hp my rear end has 3.42 gears i wanna put a turbo 350 with a ratchet .just wondering where my rpms a be at cruising down the highway at 65 could stick with my five speed but i have not made my mind up
Old Sep 25, 2009 | 08:16 PM
microkid's Avatar
March 2011 ROTM
direct drive 3rd gear, 3.42 gears = 3,420 rpms at 60 mph, so roughly 3500-3550 at 65 mph
Old Sep 25, 2009 | 11:44 PM
Cblaze's Avatar
That would not be good at the gas pump
Old Sep 26, 2009 | 12:17 AM
Jr. Mechanic's Avatar
August 2009 ROTM
Not good on the motor, either.
Old Sep 26, 2009 | 06:36 AM
Cblaze's Avatar
I will probably just stick with my five speed
Old Sep 26, 2009 | 09:13 AM
microkid's Avatar
March 2011 ROTM
yea, it is a little rough on the motor, tends to burn the rings out sooner. ive ridden in cars that had 4.10 gears and no overdrive, 5k at 75 mph is no fun on the ears or wallet
Old Sep 26, 2009 | 04:56 PM
Cblaze's Avatar
I had a s10 with a 327 and turbo 350 and now that i think about it i got like five to the gallon on the highway and the guy i sold it to said he got 9-10 driving it around town
Old Nov 10, 2009 | 11:42 PM
1989_RALLYSPORT's Avatar
i just put a 3.73 rear end in to my 305 maro an with the 700r4 when im cruising around 70 mph my tach says around 2300-2600 rpm with tc locked
Old Nov 11, 2009 | 12:29 PM
There's no way of knowing what you're exact final drive rpm's would be without knowing the diameter of your rear tires.
Old Nov 11, 2009 | 05:07 PM
Cblaze's Avatar
Back has p255 60 15 front is p215 60 15 im probably just gonna change the bell housing on my t5 and use it when i change the motor.
