Idle problems
Old Sep 4, 2009 | 09:41 AM
Black91Camaro's Avatar
Default Idle problems
I have a 91 camaro rs that I have swapped to a vortec carb. The car runs pretty good. The other day I was driviing home from work, and half way home, i realized it was not ideling normall. It normally idles at 1050 rpm. It was down to around 600, and wanting to die at red-lights. I got home and let it sit for a while. I went to crank it up, and it will only stay running if i keep it rev-ed up. Any idea what this could be? Here's a list of everything new on the car:
New vortec heads
Performer Intake
600 cfm edlebrock carb
accel super coil
accel distributor
plugs
plug wires
alternator
water pump
battery
griffen radiator
2 electric fans
fuel pump
fuel pressure regulator
Old Sep 4, 2009 | 09:51 AM
Oh yeah, i did check the plug wires and made sure none had come off or split.
Car also hard to get cranked now with this problem
Old Sep 4, 2009 | 07:42 PM
microkid's Avatar
March 2011 ROTM
could be idle adjustment fell out of adjustment or there could be dirt. however, 1050 is way too high of an idle, 700 is about where it should idle
Old Sep 8, 2009 | 03:14 PM
Well, everything looked normal on the idle adjustment. I even tried to adjust on it but could not get the car to stay running during idle. Guess i got some more playing to do. Ideas always welcome and thank you. I'll play some more with it tonite.
B_Dubya
Oct 21, 2014 11:33 PM
BrianFol
Feb 5, 2013 06:39 PM
jcase350
Jul 18, 2010 05:22 PM
delta2ul
Dec 11, 2009 04:13 AM
Sodamhot
Oct 27, 2007 11:56 AM
