flywheel issue!!!!!
Old Aug 1, 2009 | 05:21 PM
markygotacomplex's Avatar
Default flywheel issue!!!!!
so im swapping a 307 out of a "68 somthing.. my car has a t-5 in it... what can i do about the flywheel? i have barley any money...
Old Aug 1, 2009 | 06:26 PM
carl 1984's Avatar
im guessing the trans is from a 90s car so the fly wheel is going to be a 153 tooth 10.4" fly wheel that is from a internally bal. engine that u will need look on your local craigs list or call the number i called for my car 84 383 5 speed they hooked me up. 1-800-743-2562 the name of the place is THE SPEED SHOP good luck !! Carl
Old Aug 2, 2009 | 04:00 PM
yeah i found one on ebay, ive been lookin for em forever i was just wondering if there was any other way.. none on craigslist ever.. hows that t-5 holding up under the power of a 383?
Old Aug 2, 2009 | 05:46 PM
carl 1984's Avatar
actually its still not in yet. But I should get it in in about a month from now.Then I'll be worried about the trans and the stock rearend the rear is from a 1988 IROC with disc brakes with posi and a 3.73 gear.If you ever get a different gear go with the 3.73 I love it. I currentally have a TH400 in the car and it will bark the tires in 2nd and drive,one time it barked the tires going from 2nd to drive at 50 mph yes 50 I bout **** my pants.That engine of mine is a torque monster.
Old Aug 2, 2009 | 09:49 PM
Y2K's Avatar
Y2K
Won't the stock flywheel from your T-5 work on the 307 or is the problem that you have no flywheel at all?
Most Chevy flywheels and starters interchange,400 small blocks and 454 big blocks are externally balanced and have specific flywheels but the rest should swap.
I've used the flywheel and starter from a 327 on a 427 even.
Old Aug 3, 2009 | 02:02 PM
flywheel i have is from a 1988 305... one piece rear main seal, which has a smaller bolt pattern.
Old Aug 3, 2009 | 11:04 PM
Y2K's Avatar
Y2K
Ahh I see, well here's a new one for well under $100
http://www.thepartsbin.com/catalog/?...olet&md=Camaro
bglawson42
Nov 14, 2013 09:09 PM
MDThomas26
70-81 Transmission & Differential
12
Aug 26, 2012 04:17 PM
MDThomas26
Aug 13, 2012 05:31 PM
uestraven
70-81 V8 Tech
Mar 15, 2011 01:11 PM
blowncamaro
Jan 5, 2010 09:44 AM
