spreadbore or squarebore
Old May 1, 2006 | 12:18 AM
sweet1967camaro's Avatar
Default spreadbore or squarebore
i cant tell what holes are what on my edelbrock carburator. I need to know what the inner most holes on the carb that the studs go through are called. Are they spreadbore or squarebore.thanks adam
Old May 1, 2006 | 12:27 AM
Default RE: spreadbore or squarebore
Those are just hole that might be used on some intakes, if it were a spread bore carb the secondarys would be wider than the primarys
ScottD
Aug 24, 2011 12:39 AM
