Starting problem, 1991 IROC
Old Apr 6, 2006 | 09:50 PM
kshabaniani's Avatar
Default Starting problem, 1991 IROC
Hello,
My Z28 started with no problems a few days ago. It died after only driving one street block. The starter crancks but no engine turn over.
I have checked the foloowing:
- all fuses
- enough fuel
- no sparks to plugs
- no spark from coil to distributer
- battery is okay and has enough crancking power
What other troubleshooting steps need to be taken in order to determine if this a fuel problem or electrical?
Oh, one other thing, when I turn the ignition switch, I hear the fuel pump on.
Thanks,
Old Apr 7, 2006 | 04:44 PM
TimmyTheWop89's Avatar
Default RE: Starting problem, 1991 IROC
you said there is no spark at all? that means your coil has fried, happens a lot.
Old Apr 7, 2006 | 04:48 PM
mike86rs's Avatar
does that have an HEI distibutor?
Old Apr 7, 2006 | 05:20 PM
Yeah that's what I figured, so I replaced the coil. I'm still not geetting any spark from the coil.
Are the wires feeding the coil coming from Electronic Module?
Old Apr 7, 2006 | 05:23 PM
Mike,
How would I check to see if I've got a HEI distributor...
c4maro
May 17, 2011 07:42 AM
JC316
29
Feb 6, 2010 07:58 PM
mrmiller2u
Sep 10, 2009 06:48 AM
kshabaniani
Apr 6, 2006 02:02 PM
mscot77
Jul 31, 2005 12:49 PM
