72 CAMARO
Old Oct 29, 2008 | 03:53 AM
whitemike21's Avatar
Default 72 CAMARO
HEY GUYS HOWS IT GOING IM A NEW MEMEBER
SO I HAVE A 72 CAMARO AND JUST WANTED TO KNOW IF THE RS GRILL FIT MY CAMARO
AND WHERE WOULD BE THE BEST PLACE TO PUT A LINE LOCK/ ROLL CONTROL
I WANT TO DO A BAD BURN OUT
Old Oct 30, 2008 | 11:27 PM
JRs72RS's Avatar
February 2009 ROTM
Default RE: 72 CAMARO
If your car is already a RS no problem. If you are looking to put an RS grille into a standard front I do not think it will fit. The RS has a divider bar in the center that is a separate piece. You would need a different header panel, valance, nose and brackets.
On the roll control, are you talking the valve or the switch? Put the valve between the proportioning valve and the tee fitting to the front brakes. The switch can be located anywhere you want. If you have a manual trans Hurst makes a shift handle with the switch built in.
