white smoke from both exhaust pipes
Old Mar 27, 2006 | 12:14 PM
ronbo1044's Avatar
Default white smoke from both exhaust pipes
recently just bought this 95 Z28, the car had a burned plug wire, we replaced the wire, the mis-firing still occurs.. started to drive the car after changing the wire, ran hot, noticed a burning wire smell coming from the right side of bottom of block, assuming fried the starter wire.. but, white smoke was coming out of the exhaust at a pretty good interval... clouded ... purewhite, now.. when this usually happens, I would assume the head gasket let go and antifreeze just running out through the exhaust? does this all make sense?
Old Mar 27, 2006 | 01:10 PM
Default RE: white smoke from both exhaust pipes
Sounds like it could very well be a head gasket. Did you check the coolant level? Bubbles in the radiator? Did you do a comression check?
Old Mar 31, 2006 | 09:11 AM
mike86rs's Avatar
Ya I was thinking a head gasket or even maybe a cracked head or cylinder wall.
JoshMan
Jun 22, 2012 06:08 PM
BOOGYMAN1313
Jun 6, 2011 09:53 AM
REN
Oct 11, 2010 11:09 AM
vampyrico
Apr 24, 2007 01:26 PM
skiboyjr
Oct 20, 2005 04:51 PM
