Front left fog light. 69 z28
Old Sep 16, 2008 | 06:40 PM
scott14oh's Avatar
Default Front left fog light. 69 z28
Hello, I have an original 1969 z28 camaro and am having a problem with the left front fog light. The left fog light does not turn on unless it is blinking as the turn signal. The Right fog light is working. I have even tried switching bulbs and it doesnt change anything.
This is strange to me, because, if it was a problem with the switch, why would the right fog still work? Also, why would it only work when the blinker is engaged?
Thanks for any suggestions.
I have tried jiggling the wires, but it does change anything.
~~~edit~~~
I didn't know i could post this on the main page. Sorry for the double post
Old Sep 16, 2008 | 07:08 PM
Default RE: Front left fog light. 69 z28
Well, for starters, those ARE NOT fog lights. They are running/turn signal lights, and they have double filament bulbs. One filament goes on with the headlights, and the other is the turn signal. Since you seemed to have ruled out the bulb, your problem is either a bad socket (broken/corroded), a broken feed wire, or even a bad ground. My money's on a bad wire or socket. You need to dig more.
Old Sep 16, 2008 | 07:19 PM
scott14oh's Avatar
Thanks for the reply. Right, the bulb is not the problem, because it works in the other side. If its a bad socket, wouldn't the turn signal not work either?
Old Sep 16, 2008 | 07:50 PM
scott14oh's Avatar
We just found the problem. The problem is the connector that the wires lead to.
Barry J
May 10, 2015 08:59 AM
atikovi
Mar 27, 2012 07:33 PM
kpmunt
Jun 11, 2010 06:33 PM
Cowboy Joe
Feb 4, 2007 04:15 AM
