MORE POWER
Old Mar 11, 2006 | 02:12 AM
Cody's Avatar
Default MORE POWER
what else could I do to my motor to give it more power? I already upgraded my cam to a 585/590 lift 750 holley carburator, new distributor with 8mm wire, upgraded oil pump, weight reductions, got rid off all the egr crap and swapped engines to a 355 stroker...any suggestions??
Old Mar 11, 2006 | 09:01 AM
Default RE: MORE POWER
Well 355 is not a stroker it's a 350 bored .030. You best gains in HP are going to come from a head swap. Edelbrock, Brodix, AFR all make good heads.
Old Mar 13, 2006 | 11:41 PM
mattvogt's Avatar
go with the brodix heads. they are sweet but cost a ton of money. atleast for me
Old Apr 8, 2006 | 06:55 PM
mike86rs's Avatar
I have a set of edelbrock performer rpm heads and they work great. they ran me about 1000.00 dollars
Old Apr 18, 2006 | 03:43 PM
67454conv's Avatar
with that much cam you need a open plenum manifold not stock something like a victor jr and gears atleast 4:11s and a high stall or your engine will not hardly idle seeing as it will be riding on converter to much . we wont even talk front spring rates rear traction front end limiters 90/10 shocks battery trunk headers or did I just do it .Oh ya you can always put it on the boob (NO2)
Old Apr 18, 2006 | 06:33 PM
SickSickSick's Avatar
You Definately Need To Breath. A Dual Plane High Rise Intake And Headers Would Do Wonders. Sick
MaxTheKiing
Aug 23, 2010 03:21 AM
rbeard
Aug 9, 2009 12:11 AM
dkblind87
Jul 27, 2009 05:35 PM
IBADRIDE
Jul 13, 2006 01:44 AM
