temp
Old Jun 7, 2008 | 08:55 PM
rebel72's Avatar
Default temp
79 camaro 350 motor the temp runs at 190 195 at a stop light runs more hot till i drive i check the water level and it fine is this temp normal?
Old Jun 7, 2008 | 09:21 PM
Default RE: temp
It is if you have a 190 thermostat. I would prefer a 180 though.
Old Jun 11, 2008 | 05:04 PM
rebel72's Avatar
Default RE: temp
i put in a 180 still runs hot like 190 at the red light and if i put it in park and rev it up it cools down i drain the aini frezze flushed it still the same thing and aother thing is sometimes when i turn off the motor it keeps running any help please
Old Jun 12, 2008 | 12:30 AM
Default RE: temp
Check your ignition timing, it sounds like it might be off.
Default RE: temp
Most of the time it's the timing being too far retarded (pre-detonation) that makes the engine run hot.
Old Jun 12, 2008 | 12:31 AM
Default RE: temp
And timing/heat could also be the cause of your run-on problem. Sorry about the multiple posts, this site is still frigged up.
Old Sep 18, 2008 | 09:12 PM
camaro76's Avatar
Default RE: temp
ive had the same problem with my 76 camaro running hot and still does after putting a racing radiator and electric fan, i should probly check the timing
Old Dec 11, 2008 | 06:43 PM
Bab246's Avatar
Default RE: temp
I have a 79 camaro with 11 to 1 compression jasper 350 400 hp electric fan my temp was always high to my car runs a lot cooler with a 165 t stat it runs around 175 180. also timing does help try to advance the timing a few degrees check your throttle responce should be very fast to rev. Shut car off let sit for 1 minute try to restart if it cranks hard timming needs to be turned back a little should help. my timming is about 35 degrees advanced with accel ignition. Go with the 165 t stat 180 wont work to keep you in the range that your looking for
Old Dec 15, 2008 | 01:03 PM
1979RS's Avatar
Default RE: temp
what is a proper or good temperature for the engine to run on? i've got a 350 lm1 all stock
vicsponjr
Dec 1, 2011 05:48 PM
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
jeb
Feb 9, 2009 06:37 PM
thebandit110
Oct 23, 2007 06:03 PM
afar95camaro
May 17, 2007 09:13 PM
