Power windows and locks?
Old Feb 28, 2006 | 09:18 PM
imperial's Avatar
Default Power windows and locks?
Is it possible to install power windows/locks in a 01" camaro? Thanks.
Old Mar 1, 2006 | 11:04 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: Power windows and locks?
yes. im sure you can pick up the door trim panels, motors and track and make your own wiring harness. there may be a kit, but im not positive
Old Mar 2, 2006 | 04:13 AM
ChrisDK17's Avatar
I know they make power window kits for my 80 camaro so they should make them for your 01 in fact i found the window switches on www.ecklerscamaro.com but i didnt find the motors for them. i found power window regulators on www.paddockparts.com for $180 apiece. it says they are for firebirds so you may want to call them and find out if it will fit your car.
you can always try to salvage the parts from a yard but there is no guarentee that they will still work but if you do,make sure you get both motors, tracks switches and relays. You might even be able to get the power locks from the same car however, my brother just got power locks for his ford ranger and they came with an alarm set that has keyfobs for the locks and a remote start. it only cost him $140 total for the locks remote start and alarm installed.
Good luck hope i helped some.
Old Mar 3, 2006 | 01:44 AM
imperial's Avatar
Thanks!!!
93camarojb
May 11, 2009 03:03 PM
1994chevycamaro
Mar 8, 2009 11:12 PM
Lithorian
Jan 26, 2009 11:50 PM
mikew6459
May 13, 2008 04:59 PM
meteoralp45
Aug 15, 2007 11:25 PM
