back end
Old Feb 1, 2006 | 08:24 PM
rebel72's Avatar
Default back end
what could i do to rise the back end up i want it to look mean looking its a 79 camaro
Old Feb 1, 2006 | 10:29 PM
wolfin81's Avatar
Default RE: back end
Well you could use a shackle kit which you can buy from a local parts store or use air shocks.
Old Feb 1, 2006 | 11:07 PM
rebel72's Avatar
What are some good upgrades for the rear
Old Feb 2, 2006 | 02:14 PM
v8chvyguy's Avatar
I have air shocks on my '79 Z. They ride to firm. As soon as I get an origional set of rims for her, those shocks are comming off and the stock ride will be restored.
Old Feb 2, 2006 | 08:36 PM
wolfin81's Avatar
can't you adjust the ride on your air shocks? like put a different amount of air in them?
srry if i seem sarcastic long day
Old Feb 4, 2006 | 12:22 AM
v8chvyguy's Avatar
I could lower the air press but then the tires rub. The previous owner thought it would be cool to put 15x10 reverse offset Cragars w/ 255/60's on the rear. the air shocks make that possible. It looks cocky but the car was designed to be a cruiser now it rides like a tank. Keep in mind that when you change the cars stance ie: raising the rear, you also change your front end alighnment. If anyones interested here's the specs that camaro's like to be set to:2 deg caster w/ .25 deg stagger .2 neg.camber. the factory specs suck 1 deg caster and .6 deg pos camber drives like sht don't let your alighnment shop set your camaro to these specs.
Old Feb 4, 2006 | 05:05 AM
wolfin81's Avatar
wow thnx for the info!!! learned something new tonight
Old Feb 4, 2006 | 11:36 PM
v8chvyguy's Avatar
I hate to admt this, but, those specs are very close to the DKM Macho T/A, remember them?
Old Apr 4, 2006 | 01:29 AM
SABSCAMARO's Avatar
HEY V8CHVYGUY I'M GLAD I CAME HERE, I INSTALLED SIZE60 TIRES IN THE REAR AND I CAN'T DRIVE MY 68 THE QUARTER PANELS HIT WHEN I RUN INTO A SMALL BUMP ON THE STREET, PLEASE HELP. I DO HAVE NEW KYB SHOCKS
Old Apr 6, 2006 | 01:02 AM
v8chvyguy's Avatar
What size tire did you install?
