RUST PROBLEMS
Old Dec 1, 2007 | 05:53 PM
westown's Avatar
Default RUST PROBLEMS
I JUST BOUGHT A 86 TTOP IROC IT NEED A LITTLE WORK NOTHING MAJOR THE RUST IS THE BIGGEST PROB THE A-PILLIR IS THE WORST AND IT HAS 13 LITTLE SPOTS OF RUST IM GETTING A NEW FENDER CUZ THE ANTENNA HOLE IS RUSTED OUT SO MYQUESTION IS WHAT DO I NEED TO GRIND THE RUST OFF WHAT KIND OF GRINDER WHAT KIND OF WHEEL WHAT WOULD YOU DO TO FIX IT BECAUSE I DONT KNOW ANYTHING ABOUT RUST THIS WILL BE MY FIRST TIME TRYING IT
Old Dec 1, 2007 | 05:56 PM
westown's Avatar
Default RE: RUST PROBLEMS
IM
Old Dec 1, 2007 | 06:04 PM
westown's Avatar
Old Dec 1, 2007 | 06:07 PM
westown's Avatar
Old Dec 1, 2007 | 06:09 PM
westown's Avatar
Old Dec 1, 2007 | 06:10 PM
westown's Avatar
Old Dec 1, 2007 | 06:15 PM
westown's Avatar
Old Dec 1, 2007 | 06:18 PM
westown's Avatar
Old Dec 1, 2007 | 06:21 PM
westown's Avatar
Old Dec 5, 2007 | 12:51 PM
raceking46's Avatar
If you've never done metal work before I would clean up the spots on the pillar with a sanding disc and a wire wheel and use some metal repair puddy and some body filler but if u wanna try to fix it right you'll need to cut it out and make or have made some metal patches to be welded in....however from your pics I'd say you'll probably have to take the windsheild out and the T-top weather stripping to weld new peices in.
