lowering springs
Old Sep 19, 2004 | 07:07 PM
TyRob22's Avatar
Default lowering springs
i have just got a new set of lowering springs from my brother
they are for the v6 camaro but i have a z28 i was just wondering if they would still work for my Z
Old Jan 16, 2005 | 06:38 PM
spdshftr's Avatar
Default RE: lowering springs
the only way to tell is to try. if you want to lower your car you do not need new springs, remove the old ones and cut a coil out of the old one and install, one coil spring will lower the car about 6 to 8 inches.
Old Apr 22, 2006 | 12:08 PM
cheath's Avatar
ORIGINAL: spdshftr
So if he cuts out 2 coils, it will lower it 12-16 inches?? Do you know what your talking about?? Don't give advice out if your an idiot, and you could get him killed!! Go buy real lowering springs and do the project right.
Old Apr 23, 2006 | 10:32 PM
v8chvyguy's Avatar
Better yet, Go buy the right springs. The V6 springs will fit the car, but, they were not engineered to support the V8 let alone the fact that you're talking about a Z28.
Old Apr 24, 2006 | 12:14 AM
1969 SS's Avatar
ORIGINAL: cheath
ORIGINAL: spdshftr
I love that was your first post...LOL!!!
people like that shouldn't be able to post thoughts. I'm surprised he didn't just say heat them with a torch and take the temper out of them
Old Apr 24, 2006 | 12:17 AM
warthor's Avatar
Yeah one of the first things i learnt was. If you wanna lower a vehicle, dont cut the coils. So basically..... dont cut the coils.
Old Apr 24, 2006 | 09:39 PM
1969 SS's Avatar
if you do have proper coils in a car, you can get away with cutting almost a full coil off. the best way to do this is with a plasma cutter while submerging the coil in a bucket of water so you don't loose any of it's strength
Old Apr 24, 2006 | 10:16 PM
v8chvyguy's Avatar
Jeep Liberty budget boost kits require the front coils be cut. We cut them with a cut off wheel. It dose not affect the springs design caractoristics at all. you have to get them damn near red hot before you start changing temper. I still don't recomend cutting coils in situations described in this thread but it can be done very easily. You need to think about what you're saying to some of the other less experienced members.
Old Apr 25, 2006 | 01:01 AM
shnormo's Avatar
Make sure that the coil is very pure... water + high power electrical tools don't mix. Salt water conducts electricity, as will any other alkali material so watch your ***** so they don't get fried. V-6 will fit into the V-8Z28 model, just be a little bit lower and a little bit softer than the ones designed for the Z28.
ORIGINAL: 1969 SS
Krusher RS
May 23, 2013 11:51 AM
flowride
Dec 30, 2012 04:34 AM
Bri7man
Feb 23, 2009 02:32 AM
kyleag89
Feb 15, 2009 09:53 AM
