Improving Fuel Economy
Old Sep 29, 2007 | 10:11 AM
Default Improving Fuel Economy
This is from AutoTap scantool software
IMPROVING FUEL ECONOMY
Today's cars and trucks are designed to run with the best mileage, power and emissions possible, and they do a great job of it. So what can you do to save at the pumps in your vehicle? Here are some tips.
Buy cheap. Don't pay for "premium" unless your manual recommends it. There's no upside to using higher octane fuel than necessary. Some name-brand fuels may have better additive packages than no-name fuels. I don't have any hard evidence one way or another that it would affect mileage or maintenance, but it is worth noting.
Check your tires. Both for safety and economy. Keep a tire gauge in your car and check your tires every time you fill your tank. Use the pressure recommended for your car (look in the door jamb or under the truck lid for the manufacturer's recommendations).
Put your car on a diet. Don't keep extra weight in your vehicle.
Keep in tune. Keep up with the recommended replacement schedule for ignition components such as spark plugs. Keep a clean air filter. Be sure your fuel injectors are clean (an occasional bottle of injector cleaner additive isn't a bad idea). Use AutoTap or another scantool to be sure that you're not having problems with misfire.
Don't use the brakes! Don't take this one too literally, but there is nothing you can do that hurts your mileage more than pushing the brake pedal. Every time you push the accelerator you've made an investment in your car's momentum. Every time you brake you throw that energy away. (This and the next tip are worth 10 times all the rest!)
Watch your top speed. At highway speeds, small increases in speed require much larger increases in power. Slowing down a few mph on the highway will save you dollars. If you own AutoTap, try monitoring the "Percent Load" parameter at a couple different speeds on a flat highway and you'll see what I mean!
What about all the fuel-saving devices that are marketed so aggressively today? Total waste of money on fuel injected cars and trucks. That certainly doesn't prevent them from selling huge quantities of these high profit-margin products. But, don't mistake profitability and celebrity endorsements for science! The fact that we'd all like to believe that they work doesn't change the rules of physics.
So how do they get away with their outrageous claims and "proven" results? One answer is the use of weasel-words. Remember "Up to 10% Savings" includes the number zero!
Some of these devices add an airflow obstruction in the intake. While I haven't tested any of these devices, I have seen test results on another engine modification that performs a similar function. The results? The intake air becomes turbulent as it passes through the Mass Air Flow (MAF) sensor. When the air flow is turbulent the sensor gets confused. On some vehicles, this causes the engine to run temporarily lean. This could improve mileage (at the expense of emissions, durability or power).
speedemon
Oct 24, 2017 01:15 PM
libertyforall1776
Oct 3, 2011 07:40 AM
nadeem
Jun 22, 2010 05:08 PM
bvans
Jul 22, 2009 11:13 PM
red star
Jun 27, 2007 10:54 PM
