Camaro Forums - Photo Galleries - Create an Account - Chevrolet Camaro
Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > Camaro Models > 4th Generation > LT1 Camaro
Reply
Thread Tools Search this Thread
Old 09-10-2007, 11:55 AM
muscleman muscleman is offline
Default what is this?
my 94z has a bad"hobble" while driving, and a low rpm miss at idle.i finally found the code its throwing at me. i found troublecodes.net and it said 18 was "injector driver circuit voltage to pcm was wrong for 4 seconds". im feeling kinda dumb but what do i look at? ive replaced ALL ignition electrical parts( brand new msd opti, wires, plugs, coil, module)ive gone over them a few timesto make sure everythings on right. any help would be great,thanks
This ad is not displayed to registered members.Register your free account today and become a member on CamaroForums!
__________________
1994 LT1 Best Run:13.23@105.67mph
TCI built4L60E,ShiftKit
Catback,CAI,Full MSD, 6aL,52mmTB, Pacesetter LTs, smog/egr delete, computer tune
eaton trac-lock posi unit, 3.73s
Old 09-10-2007, 12:30 PM
02StanGT's Avatar
02StanGT 02StanGT is offline
Send a message via Yahoo to 02StanGT
Default RE: what is this?
The only thing I can think of that it may be, is a faulty injector. That would explain your symptoms.
__________________
1999 Mountaineer AWD 5.0 - A few bolt-ons, HID projectors, and Explorer grille
1997 RS - HPTuner, Bolt-ons, needs some fixing
2009 Impreza WRX - A few aesthetic mods, HIDs
My FQuick
Quote:
Originally Posted by My new friend View Post
You don't have to make somebody sound stupid just because they're not the walking encyclopedia of camaro
Old 09-10-2007, 12:39 PM
i was thinking along those lines as well, im just wondering if its faulty wiring, or the injector(s) themselves.. is there a way to test any of these?
__________________
Old 09-10-2007, 02:41 PM
02StanGT's Avatar
You can listen to each injector to see if they are all firing. They make a clicking sound when they fire. Below are some quotes from another site, pertaining to your problem.
"Some injector's terminals are prone to corrosion. Clean and use silicone grease in them. Older connectors can get brittle due to the heat, replace damaged connectors if needed."
"A 9 volt battery can be used to check for stuck injectors, listen for a click. Don't use the car's battery for testing, it can overheat the injector coil, (especially low impedance injectors). Just because an injector "clicks", it doesn't mean that it flows correctly, it just indicates it's not stuck.
If injectors are stuck after sitting for a short time, sometimes a "tap" with a small hammer on the metal body can free it. Don't break anything... I said "tap". If that doesn't work, send them to us. "
__________________
My FQuick
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
