engine washing
Old Sep 8, 2007 | 10:57 AM
CamaroKid16's Avatar
Default engine washing
Hi guyz, is it possible to power wash the engine bay, do i need to take off the air filter or what?
Old Sep 8, 2007 | 11:02 AM
riceeater's Avatar
Default RE: engine washing
you can, but cover any electronics and the intake so you dont short/get water in the motor, not a good thing
Old Sep 8, 2007 | 12:52 PM
lovelacci's Avatar
Double check your plug wires and such afterward, too. Might knock one loose if you get too close.
Old Sep 8, 2007 | 01:27 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
The bay is designed with elements in mind. So it can get wet, otherwise the instructions would say "don't drive in the rain". Like lovelacci said above, double check the connections when you are dont to make sure you didnt knock anything loose.
Old Sep 8, 2007 | 01:34 PM
ok, yea i figured i could, but i thought i would just make sure. so just seel any places that water could get in, check connections afterwards and i'm good to go. AWESOME! thanks guyz
Old Sep 8, 2007 | 06:15 PM
It is probably safer to steam clean than to power wash, as you don't have to deal with the high pressure forcing water where it is not supposed to be, and the hot steam dries out much faster giving it less time to penetrate the wiring. But either way, if it refuses to start, you know why. And if it was an LT1 engine, don't even think about it. LOL
Old Sep 8, 2007 | 07:43 PM
Chappie99's Avatar
soak it with engine brite, then use a garden hose..
Old Sep 9, 2007 | 12:45 PM
350rs's Avatar
March 2008 ROTM
when i wash the bay of my truck, i usually cover the distributor and alternator with a plastic bag. and i use a minumum amount of water. While these things can get wet, i wouldnt push my luck if i were you.
Old Sep 10, 2007 | 01:03 PM
1969 SS's Avatar
ORIGINAL: Chappie99
best advice. high pressure can cause funny things to happen. just try to avoid the electronics best you can
Old Sep 18, 2007 | 07:29 PM
chrshadil's Avatar
If you have to pressure wash it at a car wash, make sure you leave the engine running cause it might be hard to start if everything is wet. Dont washif itis an LT1, I learned that the hard way.
