ECM Problem???
Old Aug 29, 2007 | 09:44 AM
evansrs's Avatar
Default ECM Problem???
Hello..I have a '92 RS V6..
The problem..Sometimes when I try to start it ..it will turnover but not fire at all.If I just turn the ignition key to the start position but not crank it,the checking engine light flashes and there is a clicking under the hood around the relays on the drivers side firewall and the fan will spin then stop everytime it does this.It also makes a clickingnoise on the part just above the TPS.Today when it done this I took out the fuse for the ECM and put it back in..Then it fired up.......Any and all advice would be appreciated....
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
Beest
Jun 27, 2010 02:42 AM
IZZY1967RS
Jun 15, 2008 11:11 PM
2lucke4u
Sep 1, 2006 09:55 PM
