89 camaro 3.4L conversion problems
Old Jul 19, 2007 | 10:06 PM
Shorty's Avatar
Default 89 camaro 3.4L conversion problems
I just put a 3.4L in my 89 camaro rs in place of the 2.8L. I can get the new engine to start but it idles at around 2000 rpm's and if i give it gas it cuts out. I tried the timing and it was fine. all the vacuum lines are hooked up correctly and the plugs are new. I can't figure out what the problem may be. Any suggestions?
Old Jul 19, 2007 | 10:50 PM
MadMikeZ28's Avatar
Default RE: 89 camaro 3.4L conversion problems
Maybe a bad EGR??? Maybe the computer needs a little time and ignition cycles to relearn. Can you give it gas easy? How many times have you started it and how long have you let it idle?
Old Jul 20, 2007 | 10:16 PM
Shorty's Avatar
I can give it gas easy up to a certain point. I've had it running about 5 times letting it idle for about 5-10 minutes at a time.
Old Jul 21, 2007 | 12:37 AM
MadMikeZ28's Avatar
If you can drive it try to do that. Just don't go far. My brother has a 90 with a 3.1 MPFI and he says any time he has the battery disconected he has to go through a few drive cycles before it relearns. Did you have this problem before?
Old Jul 22, 2007 | 10:09 PM
Shorty's Avatar
No but what you're saying makes alot of sense. I'll give it a try.
Thanks
Old Jul 22, 2007 | 10:15 PM
You may consider changing the MEMCAL chip with one calibrated for a 3.4 engine. About $60 from GM.
KDavis_24
Jun 29, 2015 11:21 AM
subarunut
Apr 23, 2014 04:40 PM
RedFlame
Dec 8, 2011 09:12 PM
pritchr1
Jun 15, 2011 12:15 AM
