Bent driverside Axele
Old Apr 13, 2007 | 03:17 AM
jaimejames2's Avatar
Default Bent driverside Axele
Hi to all, I just bought a 1997 Special Eddition 30th Annaversary camaro with a bent axele, it was curbed, but the car still runs and gets off on the possy.Could it just bethe axele? Or is there something else I should worry about? I am concern that the gears or the differential might be bad.And are both right and left axels universal.
Old Apr 13, 2007 | 02:19 PM
Default RE: Bent driverside Axele
If just the axle is bent, you should change it before it stresses out the other parts. If the housing is bent, you may be able to get it straightened, otherwise get a good one from a salvage yard. It is not a good idea to drive around with a bent axle.
97LT1
Mar 9, 2011 09:40 PM
_Pirate_
Jul 3, 2009 11:23 AM
beatup90rs
Jun 25, 2006 02:20 AM
