69 Camaro LS1
Old Feb 26, 2007 | 04:22 AM
69camarokid's Avatar
Default 69 Camaro LS1
Has anyone actually been a part of a first gen ls1 swap. im trying to fnd exactly what parts ill nedd and where i can get them, thanks
Old Feb 26, 2007 | 08:39 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: 69 Camaro LS1
I havent personally done this. I would think that the electronics (wiring) and fuel delivery would be your biggest hurdles. Is the car or engine manual or automatic? The 69 uses a mechanical fuel pump at the engine. Is the motor EFI? These are some question I would be asking.
Old Feb 26, 2007 | 02:07 PM
to answer your question the engine is the original 307...EWWW, haha and is backed by the also original turbo 350.
Old Feb 26, 2007 | 09:26 PM
JRs72RS's Avatar
February 2009 ROTM
I have not worked on an installation into a Camaro, but we are in the midst of installing two LS1 in 57 Bel Airs. The first thing you will need is a wiring harness. There are a number of aftermarket parts out there to do this. You will need the ECM also. One of ours uses the factory computer, the other is an engine from Turn Key and has a much smaller unit that we are attemting to identify and source. Injected engines need a good source of fuel, for simplicity sake we used an inline MSD pump from Summit and a fuel filter for a 99 Corvette which has the regulator built in it. For trans we used 6 speed Tremec on one and 700R4 on the other.
